I want to do an engine and transaxle swap.
2GR-FE + U660E into a non-Toyota vehicle.
I have the dimensions of the Engine thanks to the internet.
I don't have the dimensions of the transaxle - Length, Width, Height
I have the weight though - Weight: 94.4kg - 208.1lbs
I know Toyota TIS can give me that information but I would rather subscribe when I am ready to do the swap.
I am currently researching the viability of the swap at the moment.
  • You should get the transmission so you can do precise measurements as +/- 1/2" will not do and neither will a wag...
    Mar 20, 2021 at 13:09
  • @I would agree with you Mar 20, 2021 at 14:48
The U660E has many applications including the Camry.
I found the following figures for the application in the Camry:
Length: 570 mm (22.4 in) Width: 620 mm (24.41 in) Height: 510 mm (20.07 in)
With this information I have data I can play with to compare with the size of the transaxle in the vehicle.
Data obtained from Toyota!
