Why would I have an extended crank after replacing all of my injectors and also have rich bank 1&2 codes? Have double checked timing and vacuum,all seems ok. If I shut it off and start it right back up it starts fine. I did not have these problems before. Could I have gotten bad injectors?
  • Welcome to the site, what do you mean by 'extended crank?' Do you have any codes? – GdD Mar 17 at 12:58
  • It sounds like you have leaking injectors. – Pᴀᴜʟsᴛᴇʀ2 Mar 17 at 16:06
  • I bought cheap injectors off rock auto, could this be a common problem ? – John Reece Mar 18 at 2:07
