Air will not come out of vents for either head or legs. The blower works just fine and I feel air coming into the cabin at different crevices of the dashboard but I don't feel anything when I put my hand or arm over the vents. Heating and cooling works fine as well.
I checked the HVAC fuse and it's good. Other than that, I don't know what could be causing the problem. Another fuse for it that's bad, a bad relay, or a loose connection? Thank you for everyone's help.
Edit: Another thing I should add is that the circulator fails to come on when I try to turn it on. Defrost will work however. Air will come out of the vent for defrosting the windshield, but not the vents for head or legs when I set it to that.
