it no longer puts out wifi thank you
tried turnning it off for a day, it has no reset button on the unit or PCB
here is more information: Here is more information https://security.stackexchange.com/questions/245951/wi-fi-station-wont-connect-to-ap-wpa2-psk
There is no standard procedure as all vendors are using custom hardware (although many are based on the ancient ELM327 "reference" design). If a power-cycle doesnot help, it's most likely broken or (depending on its capabilities) misconfigured in a state that prevents the WiFi to come up.
Check with the vendor whether it has a hidden reset button or something along those lines.
