Last night my passenger window didn't roll up after rolling it down part way. This didn't surprise me as it had been moving sluggishly for a few weeks now. What did surprise me though was that now. Only the driver side window works. So I was curious if the other three may be on a fuse together, and if not any idea what it might be?
  • Do you have a window interlock switch? have you checked?
    Feb 2, 2021 at 21:22
  • Welcome to Motor Vehicle Maintenance & Repair! Feb 2, 2021 at 22:14
  • There is a child lock that turns off the windows except the drivers ( in 2004 model). . But that would not explain sowed movement. Feb 2, 2021 at 22:17
To answer your question, no, they all use the same fuse. Since the Titan didn't do a "refresh" of the first generation until the 2008MY, I'm pretty sure your Titan should be the same as a 2006MY. Here is a fuse diagram from a 2006 where you can find the 50A fuse which supplies the BCM and windows (ignore the red circle ... the fuse is up and just to the right of the red circle; it's marked "BCM/PWR WDW"):
Usually when a window starts moving slowly, then dies altogether, it's due to the motor going bad. If the motor goes bad, you need to look at the regulator, as it can cause premature motor failure. You can attempt to power each motor individually, but usually it's just better to replace them.
