The valve cover gasket on my 1998 Ford Escort zx2 has failed. I have ordered a new gasket and plan on replacing it myself because it looks easy enough. A few videos I watched indicated that a sealant should be used, but they didn't mention specifics. I already have some red high temperature RTV. Can this be used? Should it go on both sides of the gasket or just one side or the other? Should it go over the whole perimeter or just the corners?
1Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2♦ Jan 19 at 23:23
Provided that the red RTV you have is oil resistant (which, according to the packaging you linked, it is), it should be fine for this application. The packaging specifically says it's intended for valve cover gaskets.
In my experience, you normally apply RTV to seams in the sealing surface and at sharp corners, but otherwise should keep the RTV to a minimum. If nothing else, applying it unnecessarily makes a mess and makes it harder to take it back apart without destroying the gasket.
Be sure to follow the torque and application requirements of the RTV - it's not always just to apply and torque down! Some of them have waiting and curing times before torque should be applied.
