I bought a 2004 Prius with 270k miles on it about 1.5 months ago. I’m a delivery driver, and drive about 200-300 miles per day.
About 1 week after buying the Prius, the code P0A93 popped up for the first time. The red triangle of death would disappear and pop back up once every couple of days or so after that. Pretty much everything I saw online says this indicates an inverter coolant pump failure. I had it replaced.
The first couple of days after replacing it, I was really hard on the car, trying to get the error to come back. Before, it came up every couple of days under normal use, but it never did during this period. So I was pretty satisfied that we had fixed the problem.
1 week and around 1800 miles later (today), the red triangle flashed while I was on the freeway going around 72. I hooked up the OBD2 scanner and it said there were “0 codes.” I thought that was weird, but went in and “read” the codes anyway. Sure enough, the P0A93 code was there.
Is the fact it said “0 codes” indicative of anything if it went on the read out the old code (usually, it would say “1 code” after the red triangle popped up)? Is it possible the red triangle popped up as a result of a lingering code from before it was fixed? What’s my next step?
