I have looked through the questions recommended by SO and none of them seem to address this specific issue - and it's the only one the car has, otherwise it's in immaculate condition.
It is a 2007 Scion with automatic transmission. In the morning when I drive it, I've just gotten used to the fact that it will only go to second gear for about the first 60 seconds of driving. No problem, I live in a suburban area, just go slowly around 30MPH and eventually it will shift into higher gear. Possibly, maybe, a bit longer on a cold day but not much.
My suspicion is that there is a gummed-up something that releases as soon as the transmission is warm.
My question(s) are, what is the likely problem, is it likely to get worse, and is there any non-invasive approach (like additives) that would be a good first try in order to resolve it? Thanks!
  • Some years ago I had the use of an automatic Audi for a time. It would not shift into top gear until the engine had warmed up a bit. I thought it was a design feature to stop it labouring when cold, but it was annoying. The owner told me it had been like that from new. Jan 9, 2021 at 19:41
I've seen this complaint recently on this site. Turns out, Toyota designs many models to stay in low gear purposefully in cold weather to warm-up the transmission. It's perfectly normal and will not get worse.
  • that's unusual, I'm fine with it. Thanks for the link. But my only wry observation is, this is Texas where it's 100 degrees in the summer ;) Jan 11, 2021 at 2:07
  • @Oliver Williams - Upon rereading your original post, I see you have the problem for only the first 60 seconds of driving. People who live in cold climates have it for several minutes.
    – Carguy
    Jan 11, 2021 at 4:32
