We took our Kia Optima Hybrid (2014) to a shop for an oil change. We've had the car nearly three years, no engine issues at all. Normally, my husband and his dad handle the oil changes, but we were going on a long trip, so we decides to take it in to make sure there were no other issues either. The shop came back that there were two leaks. Odd, because we have had no oil spills where we park the car, but okay. Give permission to fix. We get the car back almost a week later and it seems to be working. No signs of spills. About 40 days later, my husband is driving home from work and the engine starts making a horrible noise. He pulls over and listens to the engine trying to figure out where its coming from. I suggested maybe to check the oil. He says we just had the oil changed, the oil should be fine. He checks it anyway after the engine cools. It's literally bone dry.
How is this possible? This tells me the mechanic that did the oil change did someone wrong, or didn't put enough oil back in it? The engine needs to be replaced now and its not something we can afford.
1Welcome to Motor Vehicle Maintenance & Repair! Personally, I think your instinct is correct. i'd be blaming the shop who did the work as well. Either they didn't put enough oil in the vehicle or it leaked out somewhere. If you still weren't seeing oil where it is usually parked (after the work), then catastrophic oil loss occurred (burst oil pipe or the drain plug fell out because it wasn't tightened correctly). Again, I'd still point back to the shop who did the work. Mind you, guilt is hard to prove in these situations. – Pᴀᴜʟsᴛᴇʀ2♦ Jan 6 at 18:14
Agreed, the guilt will be very hard to prove! We never did see any signed of an oil leak at all. Thank you for your feedback! I really appreciate it! – Katrina Harrison Jan 7 at 21:11
You're probably right. Have the car inspected by another mechanic, verifying in writing that there are no oil leaks. Sue the oil change shop in your county's small claims court, telling the judge just what you've told us in your post. Sounds to me like you'll be awarded half the cost of an engine replacement. If, after inspecting the engine, oil is leaking from the "repaired" leaks, you'll probably be awarded the full cost of an engine replacement!
Most small claims courts deal with grievances under $10,000. You represent yourself, so there is no need for an attorney. Present as much evidence as possible, like receipts, pictures, written estimates for the cost of another engine, etc. Be sure to start by asking for a full-cost engine reimbursement. There are likely no court fees and no downsides for trying, so you really have nothing to lose. Good luck!
Try to collect evidence from the shop that did the work too, for example you could call them and say that your husband insisted on having paperwork on the repairs because he's meticulous or something. Don't tell them about the leak. – lericson Jan 7 at 15:43
Thank you for the feedback!! Trying to gather as much information as possible. We've now spoken to two different mechanics about this situation and they have both also agreed with the assessment. This could be a long annoying issue, but it's better then having and unusable brick. – Katrina Harrison Jan 7 at 21:10
If a mechanic is willing to testify in court, you could offer him some money to bolster your claim before a judge. There is nothing unethical in doing so. – Carguy Jan 8 at 4:35
