I have a Fiat 500e 2014 that I purchased with front taken apart but with air bag sensors on their harnesses but not bolted in place. I can not find the location the two sensors should be located in the front of the vehicle. Where are the front crash sensors located on a Fiat 500e 2014?
Any bolt points close to where the wiring harness runs? That usually works as a clue. One thing is sure they win’t be fixed with duct tape... – Solar Mike Jan 1 at 7:48
Thank you Solar Mike. I’ll look every which way, but needs bolt hole and hole for key that sticks down, so pretty specific. I was looking to far forward as compared to other cars. Will go out and check now. – Jeff McCracken Jan 1 at 16:38
1Thank you, found bolt hole and other hole between hood latch and headlight on back side of beam at the top. Again thanks and Happy New Year. Jeff – Jeff McCracken Jan 1 at 18:45
