I have a 49cc 2 stroke engine in the following format:
I also have a 12V electronic starter like this:
However what I am currently lacking is a bolt/shaft to connect the electronic starter with the engine and gearbox. I have found several locations where I find the apparently appropriate part to buy, however all of them list it as "out of stock" or "discontinued by manufacturer". Here is an example:
https://www.urbanscooters.com/products/electric-starter-bolt-shaft-part-260-26
Does anyone know what the proper name or maybe a number for this part is?
  • what is your scooter brand? model? because different manufacture have different model of starter or bolt or shaft. it could damage your scooter if you got wrong parts. Dec 31 '20 at 6:25
  • It is an in-progress DIY project, not for a full scooter. The part linked is (or was) typically sold in bundles for that engine and starter. Also the measurements match what is specified for the starter. Dec 31 '20 at 6:31
  • are you going to install the starter where the pull start is now and are you sure that the starter is made for your engine. Dec 31 '20 at 6:54
  • It goes between the clutch and the motor case like here (the gray block in front of the black clutch): ae01.alicdn.com/kf/HTB19hpyMFXXXXblXVXXq6xXFXXX4/… Dec 31 '20 at 6:57
  • you have posted pictures of two different motors,is the one in your question the exact type you have or is it the motor type in your comment? Dec 31 '20 at 7:12
