https://www.harborfreight.com/battery-disconnect-switch-97853.html
The shank-end (in red-circle) is designed to be connected to an existing negative lead. Attempts install the device on an Integra and Camry failed because the diameter of the shank is not wide enough for a secure fit.
I tried purchasing another similar device from AutoZone, however, the switch had the same problem. Is there a step or process that I am missing something?
OEM cable diameter is too large for shank:
Zoom:
