The compressor isn't working because the belt isn't turning causing it to spark and smoke a little bit when I crank it. That's without the AC or heat being on. Also, when I drive it it makes the loud squealing noise until I accelerate up to a good little steady speed then it quiets down to light squeak until I slow down again. When I get ready to stop sometimes it just does on it own. So what could be the problem?
Update from OP:
2010 Mitsubishi Galant SE making horrible squealing noise and the RPM's go up while just idling is what I meant!!!
  • Hi Tina! Welcome to our community. I added your update to your question, but I can't quite figure out the "sent up" means in the title. Are you able to edit it? Dec 13, 2020 at 18:27
