I went to a repair shop a day ago and I have my clutch fixeed because it was leaking. The mechanic because said because it was due to the rubber cap, so i replace the rubber cap and the valve So i went home with no issues
After 2 days, i have a problem with shifting the gear. it became so soft when shifting it BUT i had a hard time pressing the clutch so hard so it will engage.
what is the possible problem to this? did the mechanic didnt put the parts well or the rubber cap was small?
It happened two days after i repaired the clutch.
  • Can you take a photo of the part he replaced? – HandyHowie Dec 4 '20 at 14:27
  • @HandyHowie. this one, its the secondary clutch. encrypted-tbn0.gstatic.com/… – Joseph Dec 4 '20 at 14:33
  • @HandyHowie. when i shift the gear, there a sound like a pak. When i shift it, there a kind of friction at the end – Joseph Dec 4 '20 at 14:36
  • Clutches are solid discs. They don't leak as they contain no fluid. Are you, perhaps, referring to the clutch master or slave cylinder? – 3Dave Dec 5 '20 at 1:12
  • @3Dave. I just got the mechanic fixed it. He said that i only replaced the rubber cap of the secondary clutch. Maybe the primary clutch also complains. So he adjusted the rod of it. Is that normal? – Joseph Dec 5 '20 at 1:52
