I just bought 4 winter tires for my car and all of them look identical to me. Shouldn't I get two tires for the left and two tires for the right side of the car?
Are these tires symmetrical? Well yes and no. The threads at the outer surface of the tire (i.e. the surface that touches the road) are symmetrical (see the first image). However, the pattern at the inner surface (one that faces the rim) is clearly asymmetrical (see the second image).
By the way, there are no markings that say "inside" on the tire's cheeks. There is a yellow dot printed on each tire (one side only). I guess I can flip the tires 180 degrees in order to match the rotation direction. However, if I do that, the inside pattern will stay asymmetrical (with respect to the car), and the yellow dots will be visible on one side of the car and not on the other.
I'm confused and I don't know what to do. There is no installation manual to find for these tires.
Can anyone tell me with certainty if it ok to use these tires on both sides of the car? (or did I get only left-side tires)
