I have a Honda Accord 2008.
I followed the Service Manual and identified that there is no continuity between the terminals of the A/C Pressure Switch. Since the refrigerant was only refilled last year, I plan to take a bet and order a new A/C Pressure Switch for replacement.
According to this article :
Typically, the A/C system does not need to be evacuated prior to removing the A/C pressure switch. This is because there is a schrader valve built into the switch mount. If you have any doubt as to the design of your system, consult the factory repair information before switch removal.
But I couldn't find any information in the Honda Accord Service Manual whether there is a schrader valve built into the switch mount.
Does anyone know the answer or where I can find that out?
  • There has to be somewhere on there to check pressures as well as fill the system. Nov 14, 2020 at 2:14
  • Ask a tech at Honda.
    Nov 14, 2020 at 6:05
  • Or purge the system, change switch then refill, must be possible as you had it refilled last year.
    Nov 14, 2020 at 6:12
  • I was hoping to do it at home and not go to the mechanics again @solar-mike
    – Song Keang
    Nov 14, 2020 at 8:37
  • If you buy the switch or see photos with enough detail, you should be able to see if the threaded mount fits a schrader valve, and will press in on the center pin. (Looking briefly at rockauto, it doesn’t look like it fits a schrader valve. It threads into a female fitting.
    – Tim B
    Nov 14, 2020 at 20:51
