The car is a Volvo V70 2.0 D4 181 Momentum from 2014.
I bought it used in 2016, but in 2017 it started having problems with the automatic start-stop thing, and a year later it started saying "battery low" when parking. I have had it checked out by a garage, and they say that the generator and battery are in good condition.
Since then, the problems have been stable, but persistent. It has not had start-stop for a long time now. I recently read that start-stop requires a certain type of battery, and I do not know if that is what I have installed.
I'm thinking I should maybe buy a brand-new "proper" battery ... but I am unsure of the consequences of simply unplugging the battery in a modern car.
Do I need to have a garage do it? Can I do it myself, and if so, is there a certain protocol I should be following (beyond terminal dis/connect order), I mean to ensure the electronics and locks and such don't go wonky on me?
8
  • Have you checked out what a "proper" battery is for that car? Many sites on the internet have lists and many shops have catalogues showing the correct batteries.
    Nov 10, 2020 at 9:50
  • To begin with I'm more concerned of dis- and reconnecting "any" battery.
    – noughtnaut
    Nov 10, 2020 at 13:36
  • Make sure you have any codes like radio the disconnect negative first and reconnect last.
    Nov 10, 2020 at 13:46
  • "Any codes like radio" - yeah well, my "Media Infotainment" manual is 2.5x larger than the manual for the car itself, but doesn't (seem to) list any "codes" - I think, if these exist, they're only listed in service manuals?
    – noughtnaut
    Nov 10, 2020 at 13:48
  • Usually on a credit type card or metal tag for the keyring, may be written inside service book etc Seriously suggest you find it before disconnecting your battery. Otherwise your next post will be “radio does not work, how do I get the code”...
    Nov 10, 2020 at 13:50
