I am looking at the flywheels for Chevy v6 4.3 and see one is Goodwrench version {?} and one is NON Goodwretch version. I have a 1991 one-piece rear main seal. WHICh one do I need? The engine is going into a Jeep with a T-90 trans but I have the adapters and shaft for the mechanic who's to install. The adapter calls for 11-inch Clutch and pressure plate which I have. WHICH flywheel is CORRECT? THANKS!!
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Nov 6, 2020 at 23:57
Which one matches the T-90 trans?– Solar MikeNov 7, 2020 at 5:10
Umm, as far as I know, that is not a link-up issue. The adapter is just to make V6 fit and has a shaft to act as a go-between. The Clutch & pressure plate, and I guess, the flywheel is ALL on Chevy's side of the conversation. What do I need to CHECK the number of BOLTS on this one to tell anything?– gEToNov 7, 2020 at 18:28
