I replaced my head gasket and once I got to putting everything back together my car wouldnt start it wont crank and I have no power going to my car and suggestions
check the wiring, all the way from the battery terminals to the starter and control circuits. – Solar Mike Oct 29 '20 at 5:58
About the only thing you should reasonably have disturbed electrically, that would prevent cranking, when doing this work is disconnecting the battery? – Caius Jard Oct 29 '20 at 7:31
Solar mike/ could the starter still be the problem even know I didnt work on that part – Jose Jose Oct 29 '20 at 16:14
Caius jard/ so I tried jump starting the battery I checked the connections all is good and the battery got checked as well and thats good so the battery has power – Jose Jose Oct 29 '20 at 16:15
