I'm wanting to buy a 2020 Toyota Sienna Limited (premium) but I want to be sure that it will fit my old snow tires/wheel/rims that I have for my 2014 Toyota Sienna Limited.
btw, the rims I have are: 17 X 7.5 5-112/114 ET40 PL ORIO from TireRack
Does anyone know?
Thanks, Scott
  • check the sizes on the 2020 model - may fit or may not... my car can have 16, 17 18 or even 19" as standard so you have check. – Solar Mike Oct 26 '20 at 18:40
  • 2020 rim size is 18" P235/55RF18 and my current snow tires are 235/60R17 Michelin Latitude X-Ice Xi2. I believe I can run 17s on a car with 18s, but wanted to be sure that the bolt pattern and length will work. – Scott Oct 26 '20 at 19:07
  • So what are the pcd values for both rims? Will those 17” clear the front brakes? – Solar Mike Oct 26 '20 at 19:31
  • Since you purchased the wheels from Tire Rack, you should call them and ask them if they fit the 2020 model. – D. SM Oct 29 '20 at 1:01
