I changed my Transmission fluid with a system that drain and fill simultaneously a week ago, and I checked the color Today, Please See the picture attached, It seems too dark, is there any problem?
1How does it smell? – Pᴀᴜʟsᴛᴇʀ2♦ Oct 25 '20 at 21:20
The smell is Normal, there is no any burnt smell, Transmission works normal and better than before too. – said h Oct 26 '20 at 9:16
1Then I'd suggest there's no issues. The fluid probably cleaned out the rest of the gunk left behind from before. If it is truly worrisome to you, then get it done again. – Pᴀᴜʟsᴛᴇʀ2♦ Oct 26 '20 at 9:19
1Also keep in mind that it's nearly impossible to replace all the transmission fluid. Even when you drop the pan, there is quite a bit of the old fluid left in the torque converter. – jwh20 Oct 26 '20 at 11:58
Some vehicles procedure calls for drain and fill, then drive, then drain and fill again. Sometimes even a third time. – Jupiter Oct 28 '20 at 23:00
Add a comment
