I’m trying to remove this cowl/scuttle panel in order to get under and clean the area which has leaves and filth inside.
I have managed to to remove the circle clips marked a in the picture.
I started taking the rubber line off which I didn’t need to and dislodged it from the clip anchor and am having a hard time putting it back in. Is leading to tears etc. How can I put the rubber ack on properly?
Clip c seems to be holding the panel in what is the correct way to undo it? I have added a picture of it based on the part number and it seems very hard to remove. May I aswell just break and replace?
Thanks
