Civic couPe vti 1999.
I am thinking about washing my engine bay with water.
So long as I remove the battery and leave car to dry for a week will I be safe from any electrical problems?
Are there other parts I should isolate?
Do people do this successfully or do they mess up?
Perfectly safe - the engine bay is not sealed, so it gets sprayed with water every time you go through a deep puddle.
Obviously don't immerse the electrical bits in water, but wiping them over will be fine.
Caveat though - there is no point! Most of the filth in an engine bay is grease or oil, which water won't shift. You'd be better off with a proper degreaser.
  • My car has a very good under engine cover protection so it keeps puddle moisture out and I don’t drive through rivers.
    Oct 18, 2020 at 7:30
Depends: If one uses a power washer and isn't cautious he can create quite a damage. While all electrical contacts are quite well isolated (the seals won't get better over time, so a 21 year old car hasn't certainly pristine seals) the high pressure jet of a power washer can enter the isolated zones (or bearings) and cause problems.
Washing with a proper degreaser, without power washer, should be fine
