enter image description hereCivic coupe vti 1999.
Engine is b16a2.
I notice there engine has a hole for what seems to be a stud. Couldn’t get my head positioned to see if it goes into the engine.
I have taken a picture from behind.
Does it look like there’s meant to be something going into this, is the hole letting air into the engine or what is it exactly?
Thanks.
    it is one of the lifting points on the engine block,you will find one on the oposite side of your engine block too. – trond hansen Oct 15 at 5:44
Use a bent piece of wire to check if it is a blind hole. It will be, otherwise you would see oil, water etc coming out...
Part if the standard holes provided during manufacture for various options...
| improve this answer | |
