I’ve had two top up my clutch fluid two times in a few days though it hasn’t gone low today.
I was looking for the leak which I believe can only occur in clutch fluid container, master cylinder, slave cylinder and related pipes however I cannot are leaks anywhere. I previously thought there was some fluid under the driver footwell however this may have been caused by a significant rain boot leak from rear when I was on a slope, maybe not. In any case I can’t really see any leak from aforementioned parts. Engine bay is quite dirty.
Could it be that there is no leak and maybe the two rounds of fluid I added got drawn into the system and will not leak further?
Or does the description suggest their is definitely a leak somewhere so no point in thinking about bleeding contaminated fluid etc until I find that?
Also from the pic you can see there is black stuff in the clutch fluid container. After adding fluid I can already see particles in it(not noticeable in pic). Gears have started to become hard again despite adding fluid.
Also if the clutch fluid is slightly more than max would that cause any problems?
Thanks. enter image description here
Clutch fluid doesn't go anywhere the only reason to get your fluid level go down is a leak. However if you drained the system for some reason (parts replacement or whatever) there might be air trapped inside the system after you fill it up. After some time that air gets to the top and fluid level goes down. Again this can only occur if you drain the system. You can get air in the system if you have leak (usually need more serious leak to get air in). My advice is check for a leak. Most of the the times the leaks come from slave cylinder check it first.
