About a month and a half ago we had a hurricane hit the area I live in. We had some bad flooding in my apartment complex and since my car was parked outside it stood in the water about a good 2-3 days. The water was about half my tire in height. Since then I've noticed that the air in all four of my tires constantly goes down. I refill them to the PSI listed and then a week or so goes by and they start going down again. Today one of my back tires went from being around the required PSI to 17 psi overnight. I can check the levels because my car let's me know when the psi is low. My question is could my tires have been damaged by them sitting in the water for those 2-3 days or could it be some other reason? Thank you
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Oct 2, 2020 at 13:34
If you have steel wheels ,they may have corroded and air leaks through the rust.– blacksmith37Oct 2, 2020 at 14:55
If the valves were submerged then water could have rusted up some of the valve components, or grit could be blocking the valves from closing completely. Try spraying some soapy water on the valves and see if you see air coming out.– GdDOct 2, 2020 at 15:22
1 Answer
My guess would be that the wheels, especially if alloys, have oxidized around the bead to allow some air through. Recommend taking the vehicle to the tire shop where they can clean the bead and re-seat it.
