I bought a Coolster (chinese) atv for my daughter and had to do some extensive work on it. But finally got it good as new, until today. I pulled the atv out of the shed for us to ride and started it. Ran fine for a minute then quit. Then I noticed a gas smell. So I looked at the carb, which is a PD24J for a 150cc GY6 engine, and found gas coming out of a tube that im certain it shouldn't be coming out of.
So my question is: What could be causing this & what do I need to do?
And its a new carburetor, but 90 day warranty has expired.
  • Welcome to Motor Vehicle Maintenance & Repair! It seems like the float may be stuck, but I wouldn't know for sure. You could rap on the bowl area a few times with the butt of a screwdriver to see if the over feed stops. That wouldn't fix it permanently I'd bet. Oct 1 '20 at 22:12
  • Ok, thanks! I'll give it a try! If it comes down to it, I'll just get a rebuild kit and do that. May even find better jets for it.
    – C_HAD89
    Oct 2 '20 at 23:12
