The battery in my car is dead, and I'm not sure whether it's the alternator's fault or just the natural death of an old battery.
Vehicle: '04 Honda Accord. The alternator was replaced 4 years ago. As for the age of the battery, I admittedly don't know. I know it was about three years old when the alternator was replaced, and I don't recall replacing it since then, however, I may have and just forgot about it. The date is not immediately obvious on the top of the battery.
About three weeks ago I noticed the battery light intermittently flickering on and off. The last time I saw this light it was a constantly-on indicator light when the alternator was failing (ran for about 45 minutes then died on the roadside). The light would come on at random times (some times it would come on when I slowed down, some days it would come on when I turned left, etc.) It was only ever on for a few seconds at a time followed by long periods of not being on (minutes to hours) but seemed to get worse if I used the car for short distances.
My initial suspicion was bad wiring, and the top of the battery was corroded, after cleaning the terminals the light came on less frequently, but worsened again.
I went away for about 10 days and didn't drive the car, when I returned the car was very slow to start and when driving it the accelerator didn't work. (Pressing the accel down the RPM slowed and the lights dimmed, I was only able to drive by taking my foot off the accel and just coasting and braking.). On occasion the engine would rev and work for a moment, but was unreliable. I managed to get the vehicle home. The battery light was NOT constantly on, and was off when I was having acceleration issues. After turning the car off it would not start again. It's evidently a dead battery now.
The car stereo has been dead for years, so I didn't notice any symptoms from that. The cabin fan has been dead since winter (bad blower motor resistor I haven't gotten around to replacing), so I don't know if the AC system would have caused any problems had it been on.
  • Welcome to Motor Vehicle Maintenance & Repair! Sep 20, 2020 at 20:28
  • Battery > Alternator
    – narkeleptk
    Sep 20, 2020 at 23:33
    if the charging light comes on when driving it is most likely the alternator that is the cause,if your battery is so bad that the charing light comes on you will most likely not have power to start your car several days before the battery fails completely. Sep 21, 2020 at 8:37
  • I'm worried about that. Fortunately (in a way) I found the battery is a 2012 battery, so it's well past time to replace anyway. I'm going to replace the thing today, and see if the charge light comes back on. If so, I'll go get the alternator tested.
    – Happington
    Sep 21, 2020 at 12:41
  • An update. I got a new battery but was unable to install it, the terminals were so badly corroded I was unable to get the battery out. I got a jump start and got the car to the mechanic down the street who is going to cut off the end of the clamp and replace them and the battery at the same time. He'll then test the charging system for me. Thanks for all your advice on here.
    – Happington
    Sep 21, 2020 at 21:18
3 Answers 3
An 8 year old battery is definitely due for replacement and could very well be the issue.
A quick and easy way to test the alternator after you have installed the new battery is to use a volt meter. I used to work at Interstate Battery and we would do it after every battery install to make sure the new battery would be getting a proper charge. You simply put the two leads on the correct battery posts (positive to positive and negative to negative) and check to voltage with the car running. A fully charged battery (which your new one should be) will sit at around 12.8 volts. With the car running and a proper functioning alternator that voltage should read between 13.6 and 14.5 volts. If the voltage is lower than this there is a good chance that the alternator is failing.
The answer was both. The battery had died and died short, which over time messed up the alternator. I was fine for a while because the alternator only acted up at high heat. Had to replace both the battery, the alternator, and the battery wiring (too badly corroded to get off the old battery.) The moral of the story is to change your battery from time to time, I suppose.
Pull the battery, take it to a shop and ask them to perform a discharge test. They might want to keep it in to charge it overnight, or you might want to charge it with an external car battery charger yourself. If the battery passes the discharge test, then you could have a faulty alternator.
