I replaced my knock sensors intake gasket cam shaft sensor and oil pressure sensor and now my 2005 chevy silverado 1500 Takes two key turns to start up, only sometimes, on a cold start. It was not doing this before hand and sometimes on a cold start it is fine. What could be the problem?
Welcome to Motor Vehicle Maintenance & Repair! Double check your connection to your camshaft sensor is good. Also, double check to see if there are any engine codes. – Pᴀᴜʟsᴛᴇʀ2♦ Sep 19 '20 at 21:03
Just checked and its all good and theres no codes sorry i forgot to mention that – Josh Sep 20 '20 at 20:06
Add a comment
