Have driven with below minimum oil for a while. No wonder engine sounded bad and even felt like car wasn’t going straight.
How can I know how much badly the performance has been reduced as a result? E.g should I check 0-60 Times are consistent with factory, should I check compression tests or is there know way to really know? Car is still running.
  • Been asked and answered on here before - do some research. – Solar Mike Sep 11 '20 at 4:54
  • Sell the car before major repairs – Tony Stewart Sunnyskyguy EE75 Sep 11 '20 at 16:14
  • @TonyStewartSunnyskyguyEE75 some cars won’t get nicked even if the keys were left in the ignition... :) – Solar Mike Sep 11 '20 at 18:38
You can't - at least not with out a meaningful baseline to compare it to.
0-60 times are very rarely going to be consistent with the factory times. Too many variables affect this - unless you know the full conditions the times were recorded in and and have a way to reproduce them (car, environment & driver) comparing to the factory time is going to tell you next to nothing. If you had some good pre-incident timing data of your own you could compare with maybe you could glean something I guess but this is a blind alley IMO.
Compression tests might give you an idea if you've done some particularly severe levels of wear/damage.
Probably the best way to directly measure the effect on performance of the engine before "X" and after "X" is before-and-after dyno runs (more realistically a rolling road then a bench dyno for obvious reasons). If you've got a before plot then try and recreate the circumstances as much as possible (same dyno, same weather conditions) and compare. If you don't have that then you can always compare to a stock plot if you can find one - but this is going to be less useful since you don't know how much your car differed from stock in the first place.
Assuming this your Civic VTi then according to Automobile Catalog the stock plot should look something like this:
Stock Civic Vti
A major loss vs stock indicate something was wrong with your particular car but not with sufficient certainty to pin it to the low oil running.
This is really the important bit, running the oil low for a substantial time period will have done some increased wear at least, but if it's still running then it's not f##ked and all you can do is keep on top of the oil better in the future and hope it stays that way.
  • Top Gear did several "after" tests of older cars ie the power and torque they had left after 10 or 15 years compared to the factory quoted values... Anywhere between 10 and 60% gone due to time, quality of maintenance etc – Solar Mike Sep 11 '20 at 10:46
  • @SolarMike Yeah another factor which makes it very difficult to get meaningful info as to whether any loss vs stock is down to the oil incident. Add in that factory quoted figures don't always match what cars actually leave the factory with and it's a crapshoot – motosubatsu Sep 11 '20 at 10:52
  • Well you can look at compression, grooves in the cylinder or metal flakes in the oil/filter. that should give some hints. – Daniel Sep 11 '20 at 13:05
