When I was in the store to replace tires, the mechanic said I should replace two rotors.
The back rotors are smooth when I touch them but both front rotors are very coarse, like lines drawn on to them but only an inch of the radius surface is smooth. He says I should replace them and mere brake pads will not do it as it will wear out fast.
I asked about resurfacing and he says that will not do either.
I can see the difference and it kind of makes sense, but I know they tend to oversell as well. So should I replace the two rotors?
