-1
i have a 1.4 TDCI Ford Fiesta mk7 and I would like to know if I can install a cone shaped air filter in this engine in order to have a little bit more sound without looking too "showy".
My engine look like this: enter image description here
Where do I have to install the filter?
  • Where the air filter box connects to the MAF sensor.
    – Moab
    Aug 29, 2020 at 21:21
  • It's a lovely 1.4 TDCI Ford Fiesta, and that's all it will be. People will think you have a hole in the exhaust, until you explain that you modified the front end to defeat the latest noise-reducing technology, much kudos (perhaps). BTW if you modify the car, you must tell the insurance company. Aug 29, 2020 at 21:38
You would have to dig into your pockets a bit and replace the entire airbox assembly, possibly with, a new map sensor that was designed for the new air box. There is no quick and easy way to add a cone filter to this motor, due to the way Ford has designed your air box assembly.
  • All right thank you :) where i can find some informations?
    – Raydar
    Aug 30, 2020 at 7:54
  • If i replace the air filter inner panel with a panel shaped from k&n will the sound get better? Thank you.
    – Raydar
    Aug 30, 2020 at 8:00
  • @Raydar - only you can answer that. "Better" means very different things to different people. With that Fiesta, there is nothing you can do that will dramatically change it - it's a small Ford engine.
    – Rory Alsop
    Aug 31, 2020 at 14:25
