Does anyone know where to find the fault code references I have a 2002 Golf with the airbag light on. With an Xtool I have the COD 12855 station code 3141 I don't really want to start soldering all the connectors only to still have the light on. So far I've cleaned the connectors under the seat. And tried a reset…. Knowing the fault code would save a lot of time Cheers Jez
Google returns nothing for that code? All I could find>>>>>wiki.ross-tech.com/wiki/index.php/Airbag_Coding – Moab Aug 20 '20 at 15:26
I've tried google as well. But thanks for trying – Jez Aug 20 '20 at 16:06
See if you can find someone with a VCDS cable or but one of the cheap ones and use the VCDS Lite software. I've found Volkswagens implementation of CAB-BUS wanting on some of the early cars but the VCDS software works wonders. It isn't expensive either. – Steve Matthews Jan 18 at 10:26
Add a comment
