Is there anything between a T15 and a T20 torx that I can use. I have tried three sets and none of them worked. I have even tried using allen wrenches both metric and sae. Please help
No. There's no bit between T15 and T20.
My suggestion back to you is, maybe it's not a Torx bit you need. It might be something other than a Torx (there are a plethora of different bits). Secondarily, you may have stripped the head out. (Note: A picture in your question of the screw you are trying to remove would have been helpful here.)
  • +1 for Plethora. Perspicuous use of pertinent wordage. – Alaska Man Aug 17 '20 at 20:03
  • Not only that but there are a bunch of different type of bits. – blacksmith37 Aug 17 '20 at 20:47
  • I found out that a square #2 bit is the answer. Thank you – ed dargush Aug 18 '20 at 4:41
  • Yay robertson ! A Canadian invention,eh ? – John Canon Aug 21 '20 at 1:37
