So I have a 2016 Yamaha R3 sport-bike, and riding it today I noticed the front end is very "loose", as in it literally wobbles through corners/turns. I was on the highway today and I used my legs to steer and the front end respective to the front tire wobbled back and fourth a few times before settling. Just put a new front tire about 300 miles ago, and this issue is really nerve-wracking as I am planning on selling it really soon. Any thoughts? The forks and tire pressures are in good condition AFAIK. Also, I progressively noticed this issue develop.
  • Sounds like you got a bad tire to me. – Moab Aug 16 '20 at 20:28
  • @Moab how so? It rode perfectly fine until recently. Also, the front end wobbles, not the tire – thediyer Aug 16 '20 at 20:29
  • Even new tires can go bad due to faulty construction – Moab Aug 16 '20 at 20:40
  • Did you do the nuts up properly? – Solar Mike Aug 16 '20 at 20:49
  • "As far as I know." Does that mean you checked the tire pressure with a reliable pressure gauge? A new tire should be balanced by a shop, especially if you installed the tire yourself. – fred_dot_u Aug 16 '20 at 22:06
I would check the following (with no weight on the front)
  1. check for play in the wheel bearings - the wheel should not rock side to side - Are there spacers required when installing the front wheel, could one of these have been missed/replaced backward? I had that happen on my bike before (once backward and another time lost entirely)
  2. check for play in the front suspension - again these should not allow lateral/front to back movement, the only real movement should be along the axis in terms of damping/recoil no other movement should be felt (minor flexing is allowed).
  3. check for play in the steering head bearings - there should be no rocking/clicking, nor should they be so free the handlebars flop around.
In addition to the answer posted by @Mauro, with which I agree fully, I'll add that motorcycle fault diagnosis is often challenging because the rider "feels" something in one end of the bike that's actually caused by something at the other end of the bike.
Thus, you should also check the rear suspension. Are the fasteners all present, and tightened to the correct torque? Is the rear shock in good shape with adequate damping (both compression and rebound)? Are the shock's mounts in good shape and torqued correctly? Are the swingarm mount pivots in good condition and adjusted to the correct amount of clearance? Is the tire in good shape, correctly inflated, and displaying no signs of failure or delamination? Is the rear wheel true, and showing run-out within specification? Are the rear wheel bearings smooth, and and free of play (i.e., demonstrating no lateral tire movement, as Mauro describes in his answer)?
