I have a 1995 model Toyota RAV4 automatic transmission. The speedometer and Odometer sometimes works, sometimes doesn't. What could be the problem causing this erratic behaviour.
The same car consumes much fuel per kilometer (1 liter for 7 Kilometers). What could be the problem behind this terrible fuel consumption?
Also when changing gear to reverse there is a there is knocking sound.
May i have answers for for these problems please.
Dare-es-Salaam, Tanzania
  • Welcome to Motor Vehicle Maintenance & Repair! Aug 15, 2020 at 13:17
  • When was it last properly serviced? Also check for loose connections.
    Aug 15, 2020 at 13:18
  • Any transmission codes in the computer? Sounds like the speed sensor in the trans is failing, but should set a code if it is.
    – Moab
    Aug 15, 2020 at 13:46
  • If the consumption meter works off the same signal as the speedo and odo, then you have used a lot of fuel to go (apparently) not very far, which would account for the bad consumption. Aug 15, 2020 at 16:58
