I have a Nissan X-trail with roof rails, looks like this:
x-trail
I need to transport 2 of these:
https://www.ikea.com/gb/en/p/melltorp-table-top-white-90280096/
I really worry this is a silly question, but I've never used the roof before - is there anything to worry about with regards to transporting these on the roof?
My absolute fear is them coming loose and hitting the car behind me. Assume they're strapped down super tight with ratchet straps (unless there's a better way) - should the nature of these desks -i.e. super flat, cause worry, about how the wind will interact with it?
Is there any top speed I should have in mind - would highway driving be problematic?
Much appreciated for any guidance.
11
  • Are they just the standard rails that run from front to back, with no side to side rails between them? – HandyHowie Aug 5 '20 at 8:27
  • It would be useful if you added a photo of the car roof. – HandyHowie Aug 5 '20 at 8:31
  • thanks, have added – Nik Aug 5 '20 at 8:57
  • 4
    I’m voting to close this question because it's not a maintenance or repair question, but about driving technique, which includes loading vehicles. I'd suggest looking at best practice guides to do this properly. – GdD Aug 5 '20 at 10:22
    @GdD Are questions on how to use features of a vehicle off topic? – HandyHowie Aug 5 '20 at 10:58
In order to transport goods, you should not place the load directly on these rails. Instead, you should fit roof bars across the rails to give support and a straight mounting plane.
Companies like Thule, Halfords and others make bars to fit the X-Trail. The good thing is these bars are suitable to use on most types of car with only the feet and clamps needing changed. My Thule bars have so far come with me across 6 cars - I do have an extensive collection of clamps in the garage now... :-)
I don't think it's safe to place two of those tables on the rack. One maybe upside down and tie it down tight, but I don't know about two. I would ask someone with a truck to help you transport them
