I recently replaced the cylinder and piston on a broken chainsaw 2-stroke engine and I found 2 plastic inserts inside the cylinder. I'm wondering what purpose these serve, and what the correct name for them is.
Plastic inserts inside cylinder
Plastic inserts outside cylinder
  • Port seals come to mind, but some parts manuals may differ.
    Aug 2, 2020 at 10:53
  • Also, if you gave us the make/model/size of the engine, it would surely help us to understand exactly what you're pointing at. As Mike states, things differ between manufacturers. Aug 2, 2020 at 13:10
