Plugged my Mk6 Ford Fiesta into Forscan Lite today, and got the following faults below.
Was curious to see that both the 021 and 022 flatline at near zero volts at 2000 rpm. That's not normal is it?
At 2750 rpm and engine warmed up, both sensors have wide fluctuations, which possibly suggests the cat is gone?
O21 graph waves look too slow to me.
The heater circuits seem to be switching fine on the harness side when you disconnect the sensors and put a test lamp across the heater wires on harness side. The bulb flashes with engine running. Have resistance reading across heater sensors.
Any thoughts.
Thanks
===PCM DTC P0693-60=== Code: P0693 - High speed fan output circuit malfunction - short to ground.
Status:
  • DTC Present at Time of Request
  • Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
===END PCM===
===PCM DTC P0646-60=== Code: P0646 - Air conditioning clutch relay circuit short to ground.
Status:
Air Conditioning Clutch Relay Control Circuit Low
Ignore this DTC if the vehicle does not have AC fitted.
This DTC may be caused by :
Open Circuit
===END PCM===
===PCM DTC P0420-F0=== Code: P0420 - Catalyst system efficiency below threshold (bank 1)
Aged or damaged catalytic converter.
It is important that the cause of the failure is investigated before the catalytic converter is renewed
The failure may be caused by one or more of the following:
Engine misfire
Check for engine misfire DTCs
Impact damage to the exhaust or catalyst assembly
Damaged plugs/leads/coils
Perform the ignition test
Use of diesel or leaded fuel
Engine oil contamination.
Engine Oil Level Too High
Make sure engine oil consumption is not excessive.
Renew the catalytic converter
===END PCM===
===PCM DTC P0030-E0=== Code: P0030 - HO2S Heater Control Circuit (Bank 1, Sensor 1)
Status:
  • Malfunction Indicator Lamp is On for this DTC
Open Circuit
HO2S11 circuit malfunction
Suspect HO2S11.
===END PCM===
===PCM DTC P0037-E0=== Code: P0037 - HO2S Heater Control Circuit Low Voltage (Bank 1, Sensor 2)
Status:
Short to Ground
Suspect HO2S12.
===END PCM===
===OBDII DTC P0030-C=== Code: P0030 - HO2S Heater Control Circuit (Bank 1, Sensor 1)
Status:
  • Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
Open Circuit
Suspect HO2S11.
===END OBDII===
===OBDII DTC P0420-C=== Code: P0420 - Catalyst system efficiency below threshold (bank 1)
Status:
Engine misfire
===END OBDII===
===IC DTC === Successful DTC reading, no error codes found
Module: Instrument Cluster ===END IC===
===RCM DTC === Successful DTC reading, no error codes found
Module: Restraint Control Module ===END RCM===
===GEM DTC === Successful DTC reading, no error codes found
Module: Generic Electronic Module ===END GEM===
