Hey there I have a 2004 4.0 Ford Ranger and I recently changed the front brake pads, and now the pedal is spongy and the brakes feel week, almost as if the new pads aren't even engaging. I bled the brakes in the correct order with a kit that had a very small container for the old fluid to go into so I only pumped the brakes a few times for each wheel, so maybe there's still air in them?? When I press the pedal it goes down a lot further and takes more pressure to stop, and when I start the truck with the brake pedal down it falls an inch or so as it should so no issues there. The only thing I can think of is when I compressed the pistons I didn't remove the cap from the brake fluid tank. Any ideas would be appreciated, thanks! :)
Did you machine the rotors?– MoabJul 22, 2020 at 17:55
When you bled the brakes did you refill the reservoir periodically? If you miss this it empties and you get air in the lines. I suspect this is what happened to you.– GdDJul 22, 2020 at 18:54
Thanks for the responses, I did not machine the rotors but I did refill the reservoir after each time and it never went below half. My guess is the one man version of bleeding didn't work as well as I wanted.– chaseJul 22, 2020 at 19:15
Are the rotors vented with a channel in the middle? If the internal supports have rusted away you get spongy brakes and poor braking.– Solar MikeJul 22, 2020 at 20:55
1 Answer
The symptoms you describe are consistent with air in the lines. I suspect your bleeding was inadequate. It's almost always a 2 person job with one pressing on the pedal while the other bleeds the air out and keeps an eye on the reservoir.
For a one person job, use speed bleeders or a vacuum bleeder.
I believe that once your system is properly purged of air the brake sponginess will stop.
thanks for the response, and my guess is that you're correct. I tried using one of those 1 man vacuum bleeder kits that was very cheaply made so I guess I'll have my dad help me do it the 2 man way and see if that works.– chaseJul 22, 2020 at 19:17
