Flushed coolant system, replaced radiator cap. A Tried Reprogrammed emc , light "turn off engine overheating" , when idiling. Fans keep running after car is off,AC on, no problems when ac off.
  • What is the temp gauge showing? Have you rechecked the overflow-expansion tank level after several heat cool cycles? Have you tried any of the burping techniques generally suggested for GM vehicles?
    – mikes
    Jul 9, 2020 at 23:36
  • Does the car overheat with AC off ?
    – ajayel
    Jul 10, 2020 at 8:03
  • Flushed and burped the system. Replaced overflow reservoir cap. Only overheats with AC on while idiling. Leaking water on passenger side occasionally
    – Gatkinson
    Jul 11, 2020 at 2:15
