My carpark is open to elements so should I be worried by elements affecting my plug in cable?
Like I would guess with rain it would be fine, but I'm in quebec so does it deal well with -30C temperatures and snow? Should I use a temporary garage (like a Tempo) or is it gonna be just fine?
My car is an Ionic Plugin.
  • Are you asking about the car, the charger or the cable?
    Jul 4, 2020 at 13:02
  • The charging cable
    – Fredy31
    Jul 4, 2020 at 20:18
I think you'll find that most charging cables are rubber-insulated and not PVC insulated so they stay flexible in the winter temperatures. Try an experiment. Leave an indoors-only extension cord to -30C temperature and try to bend it. Try the same with your charging cable. The difference should be apparent.
I would be more worried about the battery at -30C temperatures. The battery needs to be heated up or else it'll self-destruct. The car has circuitry to prevent the self-destruction of the battery by heating it but it requires charge in the battery. Leave an electric car to -30C for month unused, the battery charge runs out and it can no longer keep the battery at an elevated temperature.
So, if leaving the car at -30C temperatures, the preference is to leave it plugged in. That way, the heating energy comes not from the battery but from the grid.
