I have noticed a small box on the bottom of the muffler on a Mountfield SV150 lawnmower engine.
Exhaust with inlet box
Inside is a reed valve set up as inlet only and a small filter grill.
What is the purpose of this part? I understand these are catalytic mufflers, could it be to prevent some pressure differential? Thank you
  • I allows fresh air (oxygen) into the cat during hard deceleration. – Moab Jul 3 '20 at 14:48
It is usually to add air to the hot exhaust gas to make sure that the catalyst can cause the reaxtions to breakdown the combusted products sufficiently.
