I had my engine coolant level at "below LOW" and I was sure there is a leak. So I added 0,5l of tap water (full capacity of coolant is 5l) to check for the leak. It turned out it is not a coolant leak but simply water from AC system.
The question is - what now? Can I drive safely with such a mix up of coolant and a little water?
