i have a Coleman ct200u-ex minibike and i went offroading with it and it got all muddy and i got home and cleaned it and i feel like i flooded the engine when i cleaned it because I go to start it and it runs but you have to pull the string and then quickly rev the throttle to keep it on and it's making me mad cause i am having a lot of problems with this bike and i am almost to the point of selling it after i fix it. what do you think the problem is?
    Welcome to Motor Vehicle Maintenance & Repair! What have you done to try and fix the issue? More than likely you got water somewhere it shouldn't be when you cleaned it. I'm thinking you got some water in the gas, so you might try draining the tank and the carburetor, then refilling with fresh gas and see if that helps anything. – Pᴀᴜʟsᴛᴇʀ2 Jun 10 at 19:54
