I'm Looking at the o2 sensor data for my 2013 Corolla and don't know if B1S2 is bad or not. I've heard that o2 sensors in general should oscillate between 0 and 1 V but I've also heard that for newer Toyota vehicles, the o2 sensor should be steady at around .8V. I've linked an imgur post with pictures of my live data. I know that the A/F sensor in B1S1 is fine but I'm not sure what is considered normal for o2 sensors in Toyota vehicles.
At first the data drops really low for some reason and kind of stays there but it eventually goes back up and levels off after a few minutes. I was at idle during this time and didn't touch the throttle at all. Then I decided to see what would happen if I quickly revved it to 3500 rpm. I thought that would spike the data up and indicate that the car was running rich since I just revved it but the voltage went way down to .035V. Then it kinda moved around a bit and leveled off at .855V. The car isn't giving any codes so I would assume everything is fine but I thought this data looked a little weird.
