Apologies for the rambling thoughts and questions (new to the towing scene) . I'll summarize my questions:
1) Is the Home Depot rental trailer 3ft x 5ft compatible with 2001 Toyota Tacoma tow ball?
2) Is the tow ball considered a "bumper" tow ball, or considered attached to the frame (see pics below)?
3) Does the structural integrity of my truck look okay for towing?
4) Does this look like the standard factory installation of the bumper/frame, or was this a "custom" weld job?
5) Is it required for me to install a hitch receiver for this trailer? If not, what are some reasons for choosing to do so anyway?
Longer rambling version: I have never actually used a tow ball or a hitch, even though I have a tow ball on my 2001 Toyota Tacoma. I want to rent a small lawn and garden trailer 3ft x 5ft from Home Depot:
I just wanted to make sure that it's compatible and the truck is in good enough shape to do so. The specs for the trailer are a 2 inch coupler at 2000 lbs, which matches the specs written on my tow ball. The towing capacity of this truck is 3500 to 5000 lbs (not sure why there is a range specified instead of just a maximum...).
So when I called Home Depot and described my setup, they said that they wouldn't allow "bumper style" tow balls because they can't guarantee that the bumper is installed properly. But then they said if the tow ball is attached to part of the frame, it should be good. I'm not sure how to distinguish the difference so I took some pictures (I had removed the tow ball):
So it looks like the tow ball goes into a steel (?) plate that is a thicker/different material than the bumper itself. This steel plate ultimately is welded into the main frame:
I'm not 100% sure if this is the way the truck was built in the factory or if someone did some custom rebuilding (I purchased the truck used). I'm also not sure if the "dirty" look on everything means that the structure is compromised, or if this is normal.
The next thing I noticed when googling around is that you can get a hitch receiver kit for this truck:
It's unclear to me why you'd want to install a receiver hitch when you already have a tow ball. One thing I can think of is that the hitch receiver/ball will sit a little bit closer to the ground. Not sure if that's a desirable thing or a required thing or what.
  • Welcome to Motor Vehicle Maintenance & Repair! I've changed the title of your question to make it more compatible with the site. As it was worded, it was implying a driving question, which is off topic for the site. Also, some of your questions are very subjective. You need to either remove them or re-word them so they are not that way. If you would, please edit the question and see if you can help those portions of the question and improve them so this quest won't be closed. May 17, 2020 at 16:55
  • Bumper pull is good enough for small trailers and lower tongue weights, a receiver hitch is for large trailers and heavy tongue weights.
    – Moab
    May 17, 2020 at 21:49
  1. As long as the ball and the hitch are the same size, fit should not be a problem. The Home Depot hitches are designed to fit with most balls.
  2. A tow ball is considered a bumper hitch. For frame hitches, please reference here for images: https://www.homedepot.com/b/Automotive-Towing-Equipment/Trailer-Hitch/N- 5yc1vZc8n0Z1z18yir
    These frames mount to your vehicle frame and then you install the ball.
Any trailer I've hauled on a ball, had two chains; one on either side. Both chains are hooked at one end to the trailer and then the other end is securely connected to your vehicle on either side of the ball. It is a security measure which did not prevent a trailer I once towed, to pass me by on the highway.
I can't help but wonder if Home Depot wishes to sell you a hitch instead of just the ball...
  1. Toyota Tacoma Towing Capacity The base Tacoma and SR5 trims can tow 3,500 pounds, but when properly equipped with a towing package, they can tow up to 6,400 pounds. The 3.5-liter V6 and available tow package help this popular pickup truck tow up to 6,800 pounds or carry a payload of up to 1,440 pounds.Oct 2, 2019 For further information on your particular vehicle, Toyota provides more information here: https://www.ferneliustoyota.net/2020-toyota-tacoma-towing-capacity/
  2. I do not see any sign of weld on your bumper. It looks a bit rusty, but okay, nothing I wouldn't expect to see on an '01.
  3. Installing a hitch receiver is not required here (as in where I live). If you are concerned, check with your local Department of Transport for what is legal there. I am in total agreement with Paulster2 on the hitch receiver. I did like the double receiver though as it allowed for towing as well as mount for bicycles etc. That was the only advantage I saw.
If, as you say 'I'm new to the towing scene,' please, for safety sake (your own and others), ensure that you familiarize yourself with, and practice, cornering and most especially backing up before you take yourself out on the road.
Happy towing :)
!I just saw this on your truck. This is where one chain goes and there should be another just like it on the opposite side.1
That big rusty steel plate that is below your chrome bumper is a modification. Someone wanted a stronger point to mount the hitch ball (stronger than the factory hole in the bumper, which is visible in your last picture) and welded 'er up. The "clean" way to do this would have been to install an approved hitch receiver (as also illustrated in your last picture).
Technically, it appears that the homemade hitch ball plate is indeed "attached to the frame" of the truck; however, it would be difficult to estimate or attest to the strength/capacity of it. Personally, I would have zero apprehension if towing a trailer that small. The question is whether or not the rental entity will allow it...
