My Toyota Corolla 2007 CE, vibrates when idling or when stopped. The vibration goes away when the car is running. The vibration is coming from the engine. What could be the issue?
I recently changed the serpentine belt and valve cover gasket.
7
  • Have you checked the compressions? A rough idle can be caused by cylinders poorly contributing.
    Apr 26 '20 at 7:47
  • So you say you changed the belt and the valve cover gasket. Did these symptoms start after that or were you trying to resolve this issue with those repairs?
    – jwh20
    Apr 26 '20 at 10:19
  • Does this vibration happen in park and neutral, or just in gear?
    – GdD
    Apr 26 '20 at 10:24
  • Some engines have ECM controlled hydraulic motor mounts and when these go bad cause this symptom. If it does not have this type, a worn out regular engine mount can do the same.
    – Moab
    Apr 26 '20 at 14:41
  • @jwh20 Yes, the vibration started after chaining the belt and valve cover gasket.
    – PPR
    Apr 26 '20 at 16:23
