I have a Honda accord hybrid 2017 and I was checking the hidden screen settings and suddenly the screen went all black as attached pictures can you please help me with resetting the radio screen or check how we can solve this issue, and for info, the rear camera and right camera are working fine
enter image description hereThank you
  • Very simple find the accessories box under the steering and disconnect the radio unit fuse and reconnect it after 50 seconds. Usually some models require a code after this just in case get in touch with the dealership about the code. Apr 23, 2020 at 15:07
  • unfortunately, it didn't work if you know any other solution, please reply Apr 28, 2020 at 9:39
  • Last hope before you hand this over to the dealership, 1. Hold the power button for 2-seconds and release it after the beep. Do this in accessories mode. In case it doesn’t beep after 2 seconds, let go of it, and power off the car and then re-enter the accessories mode and continue to hold down the power button on the system until you hear a beep. Apr 28, 2020 at 13:51
  • I've tried this and unplugged all the USP portals it didn't work either Apr 29, 2020 at 13:50
  • Apologies, now you’ll just have to await until the dealership reopens. Apr 29, 2020 at 13:51
