20 year old vehicle, my windshield wiper arms are all faded and paint is starting to wear off. We live in a pretty wet climate (Pacific Northwest).
Considering that when painting, the prep is 90% of the work, I would really prefer to use a high quality paint that will actually last so I don't have to redo it in 1-2 years! Trying to figure out what that might be... So many cheap-ass paints on the market, I've been scarred too many times.
Disclaimer: I don't have an air spray gun, so looking for a spray can. I've heard that you can get 2K style paint in a spray can these days (pop mix switch, shake, and spray). These are really high quality, but can't seem to get those in Canada :(
Any advice on paint type (as far as spray can varieties go)? I'm assuming oil-based enamels are best? I've heard that Acrylic Lacquers are weak and should be avoided?
Process wise: I'm assuming my best bet is to wire wheel any loose paint/rust, then wash a good paint prep wash that will remove all oil/grime/wax, then prep any bare surfaces with zinc (phosphating, sacrificial zinc coating to prevent rust from forming under paint), THEN prime, then paint. Would an oil based enamel be my best bet? I need a flat black color.
